rear heater
  • rear heater
    hi there any one have any ideas what this might be my rear heater in my 1992 ssr-x ln130 only blows cold air no matter if the switch is in the hot position or the cold
    cheers
    mick
    Two possibilities come to mind. First is that the lever isn't connected to the valve that opens the flow of water to the rear heater. Second is possibly a big air lock in the pipework to the rear heater matrix.
    Mike G
      third option is sludge in the pipes from not being used for a dogs age...
      it's in me shed, mate.
        cheers chaps ill take it apart and have a look
          theres 2 pipes just below thermostat, take em both off and bung a hose pipe up it (with the heater in the hot position...) and plf. make sure the system is nt airlocked when you put it back together tho. good luck!
            The rear heater seams to have very fine cooling fins & as said the pipes get full of brown sandy sludge.
              cheers fellas ill try that
