I think you'll have to try your local Toyota dealer. They are very small and I've not seen anything like them, even in Maplins. In the end I used a 3mm LED in place of my dead buld. Light isn'y as bright but better than nothing. I'm going to look at a larger LED next time as the 3 mm is probably too small.
I got some fibre optic cable from maplin and I was going to try and run that from a single light source, i will post the results i don't want to take that dash apart again after this time it is a pig of a job.
