After having run a search on this subject and having read all the information that came up, I have decided to post this thread and see if any of you can help me in my search for information and advice on a small, yet quite annoying problem that has arrisen on my normally faultless Surf.
A couple of days ago, I came to lower the tailgate on my 92 K reg SSRX. I place the key in the lock and turned it to go down.......nothing
I tried again.....and again nothing
I tried a third time.......and again nothing
I went into the cab and used the window button and it went down immediately
I lowered the tailgate and then tried to raise the window using the key.......it worked
So, I again tried using the key to lower the window.....and again nothing
So can anyone give me some hints as to what may be the problem and what I should try and do to rectify it?
Any help will be much appreciated.
Typsey
Typsey
