Hi all, I wonder if any of you have experieneced a problem I am having with my 1992 Surf or could shed any light on it. My surf has been fantastic, a 2.4 model used for 2 years shifting anglers all over the U.K., always full of gear etc., and driven up a very bumpy track each day for the last year. Anyway, you all know how good they are but today I experienced my first problem. Chatting with a mate on my mobile (via headset of course!) I suddenly cancelled the call as I was alarmed to see what appeared to be smoke coming from the main air vent. It was not a great deal of smoke but certainly enough to be noticable. Stopping at a local mechanics they gave me various nods, ooohs and ahhs and said it was most likely the heater matrix burning out or possible a problem with the solinoids not kicking in some of the vents properly, therefore the air box is becoming hot. Sounds plausible but I would like to check up on the various possibitlties prior to them ripping the dash board out!!!
One thing I have noticed is that if I switch to hot on the heater the smoke is there and seems to be getting worse, on cold the problem seems to go away.
Is it smoke? Could it be steam? Cooling all seems fine, gauges just as they have been for the last 2 years. Perfect. Truck serviced as regularly as possible.
Any ideas gratefully received, many thanks, Nick Hart.
