Hello,
Been browsing for a bit but first post
Had the grinding lock stops and blown dash bulbs but the forum sored those out.
Had the surf about two weeks (93 3.0td) tried to lower the rear nearside window and it doesn't move, either from the driver's switch or the one in the rear passenger side armrest. Did a search but couldn't find anything, dodgy wires? or are these things fused individually?
Tried to fit a set of Alpine components in the rear (5 3/4") plus tweeters but too big, shame as they are a decent set of speakers. After searching on here it looks like I would have wrecked them as they are 4 ohm.
How do work out the lift on the surf? it's higher than others and has rancho shocks on the back. Do you measure from the top of the wheel to the arch?
