On my newly aquired surf I have a pair of IPF Spots fitted.  My mate has just got them working (Blown fuse. Loose wire). The lights are wired from a "box" under the bonnet which I assume is the relays and are contriolled from a module on the dash which has an of/off button and 2 buttons for mode1/mode2 (these I beleive are high/low beam), the bulb rating is 170/100watts. My questions are:
Are they street legal - If not what is the law? Can I fit lower wattage as I need to buy 1 bulb anyway?
What fuse/ cable amperage should be used/ (These were fitted prior to inport and I dont want to destroy anything.
Your help would be much appriceated
Still grinning
Skippernicky
Still grinning
Skippernicky
