Ive got and MP3 changer i put in the car when i bought it in Nov last year.  At Sailsbury a disc got jammed (not playing) and didnt eject so i had to take the changer out so it was level then the dics came back into the magazine.
The question is, there are damper adjusters on the side which you can set to horizontal or vertical, I have it on its end so which is this or should i not have it on end? Im guessing horizontal is normal mounting on its bottom
 and vertical might be on its back?  Need to sort it as i get error-01 on my headunit now cos the disc is still stuck until I take it out again...
Anyone mounted thier changer in the roof (by roof speakers?)
 and vertical might be on its back?  Need to sort it as i get error-01 on my headunit now cos the disc is still stuck until I take it out again...Anyone mounted thier changer in the roof (by roof speakers?)
