Hi everyone,I could just do with a bit of advice.Firstly, in normal conditions what should the charging gauge be reading on the dash,mine reads about three quarters all the time.The problem i`m having is that every three weeks or so i need to jump start the surf.Today i topped up both batteries with demin water,they were a little low but no plates were showing.I`m not sure though if it`s something as simple as not enough use.I only really use it for going to work and thats only a 5 minute drive.It might not be getting enough running time in to charge both batteries.
if anyone has any idears, then please ley me Know!
cheers
jack
 Nil Illigitimi Carborundum
 THE ORIGINAL CRAZY BITCH!
 ).  If one has been replaced on its own in the past, you may have this problem.  Best to get them checked independently.
