3rd gen door switches?
  • 3rd gen door switches?
    I need a set of door switches for my Surf does anyone know what other Toyota's use the same ones?
    I ordered part 84231-32040 from Amayama, after checking the part number on https://jp-carparts.com/toyota/partl...pe=10&fig=8401 (Under the Image 9 tab).
    https://galooph.com
      i just cleaned mine out with wd and gave it some wiggles to get it working again, seems that it needs to be positioned in just the right way when tightening bolt to work right so check with dash warning light or interior light when tightening
        Cheers .I tried the switch cleaner thing but it didn't work for long . Got some new ones off eBay that were for a Lite Ace van I think, cut plugs off and soldered to mine and all good!
