I’ve been searching and scratching my head on this one for a while.
I first noticed my stereo turn off then back on when I would turn on my signal, only sometimes. Then after a couple weeks I turned my signal on and the truck went dead, total power loss. Turned the key on and off a bunch of times then the power came back and I could start it and go on my way. It’s not just signals either, this has happened when I hit the brakes coming up to a stop light as well. This problem is very intermittent, sometimes it won’t happen at all for s few days, sometimes it’s just the stereo turning off and other times it’s total power loss.
I have checked my grounds from the batteries, cleaned and tightened all terminals, I have checked all the wiring under the hood and behind the dash, trying to replicate the problem (truck running with signal on and wiggling all the wires), pulled the stereo out, inspected all the wiring behind the dash.
If anyone has any ideas please help!
Thanks
Thanks
