hi my rear window works perfectly except it wont go up on the key does any body have a picture of the keyswitch or can they tell me how to change it and where i could get a new one from goes down fine and everything ok on inside button ive removed inside side panel all connections rust free hope you can help matt
rear door key switch for window
Rear Door Keyswitch
Use the below URL for info on how to remove the rear door trim and window.
http://www.showmesome.info/hilux/workshop/rear_door.htm
This should allow you access to the back of the keyswitch. You may have to loosen/remove parts of the window mechanism to get full access. Probably the switch can be removed from the key lock so you should be able to repair/replace the switch without too much cost
 Nil Illigitimi Carborundum
