...won't operate from the outside key but okay from the indside switch. When you operate the key switch you can here a relay clicking somewhere (so the key swictch itself is fine).
1) Where is the relay unit located- blowed if I can find it? Is what I can hear the regulator?
2) Any ideas what the fault might be- had the door assy appart but could find nothing obvious?
3) Tailgate window regulator - where is it and could this be the culprit?
TIA
Nevillef
TIA
Nevillef
