Hello all, right i have a confusing problem with my 1990 hilux surf 2.4 diesel manual, When running my lux is bringing the warning lights in the clock clusters on. The battery light stays on, the t-belt light is on and the other that i think is coolant low warning light is on (next to the t-belt light). The other thing is since these lights have started coming on the alternator is only charging around 11.9volts even with all the lights switched on. the battery light being on and the alternator not charging would obviously indicate a faulty alternator but why are the other warning lights on. Could this be a bad earth some where, if so are there any bad earth points on the truck that are prone to corrosion ect.
Please help as i really love this truck and not being able to drive it is getting on my nerves.
