hi
the field diode pack needs replacing and check brush pack if u can get a amp meter what u can do is leave ur headlight on engine not running for 10mins turn lights off start engine while engine is running disconnect positive battery lead at battery pole at idle speed 750rpm u should get a reading of 10amps at 2000rpm u should have a reading of 18 to 25amps if not get alternator recondition
					Originally posted by dirtydog
