Knowing nothing about realys I need to wire two up soon.
One is for the twin air horns I nabbed out of my old car (i fitted them). I dont know how the Surfs horns are switched and one has broken leaving me the high pitched on that makes me sound like noddy
, can someone tell me how to wire it please? I guess ill have to nick one or both of the signal wires from the old horns but not sure where to earth from and what terminals on the relay to use.
Also I give in to all you people telling me to relay my rear spot - the internal switch has broken so I want to switch it from the dash now, bought a relay and some more wire, what goes where??? (all i have at the mo is BATT/FUSE --> SPOT --> EARTH) obviously not connected cos it would be on all the time!
Im sorry.... you were right all along!!!
, can someone tell me how to wire it please? I guess ill have to nick one or both of the signal wires from the old horns but not sure where to earth from and what terminals on the relay to use. Also I give in to all you people telling me to relay my rear spot - the internal switch has broken so I want to switch it from the dash now, bought a relay and some more wire, what goes where??? (all i have at the mo is BATT/FUSE --> SPOT --> EARTH) obviously not connected cos it would be on all the time!
