Can anyone with a 2-lte 2.4 and a multi-meter please help?
I need the voltage at the 2 terminals on the lid of the pump measuring. It is the plug just in front of the fuel outlet on the top of the pump(mines gray, but some are white.) The readings need to be taken with the engine running at idle and around 2500 revs.
I need this info asap to assist with the fitting of my power upgrade box and to save my sanity.
Cheers, Micky
Cheers, Micky
