ahhhh!
when i did the dash I also wired in the light to my booost gauge. I have tapped into the wired that the fog light uses (to sense the lights are on to use the fog i guess) which come from the blue connector that powers the suspension switch. The light in the gauge works fine but if i turn on the fog light it blows the tail light fuse.
Is it cos i've used cable that is too thick for the gauge? Its all I had
