Folks,
need some help... fitting these white dials and taking loads of photos... and the speedo won't work. No movement at all. Does anyone have an electrical diagram for the instrument cluster, and a more detailed one of the speedo itself.
The odometer works, the needle just won't move...
Update: Found one for the instrument cluster (which doesn't really help), just need the speedo... Just want to know where to prod to see if it is getting (translating a signal) info.
Checked that the needle isn't binding... just wondering where the rest position for the needle should be...? Does the dial need to be powered and then seat the needle...? any suggestions...?
andyL
andyL
