I started my 1994 3.0l TD 4Runner today, started fine but the Turbo, water in filter, brake, engine oil, charging, etc warning lights did not go out?
Oil pressure gauge reads fine as does charging gauge!
The only out of the ordinary thing I have done before this (a couple of days before) was turn on the ignition and not start it so I could wind down the window, left it about 5 minutes before winding window up and turning off ignition.
Will be having a closer look tomorrow, but wondered if anyone has had a similar experience?
I suspect an ignition switch problem.
