I've noticed that when i put my high beam on (either using the push or pull methods) the lamps light high up, but very little light actually spills onto the road...the result being when driving along dark country roads i can light up the trees and distant objects but anything close up is not that easy to see.
My other car (renault laguna) seems different - i'm sure that when i use full beam on that car, the bulb keeps the lowbeam element lit and lights the high beam element as well. Hence really good illumination in front of the car.
I am assuming that the Surf is switching between the high and low elements...is this correct?
and can it be set up so that both elements can be lit together?
ta in advance
ta in advance
