After standing idle since mid December I decided that as I can drive a little now it was time to MOT number V.
Opened the garage, connected the battery isolation switch and she fired up first turn of the key
Got it into the MOT station and walked out with a pass in my hand with a couple of advisories :-
all rear brake pipes slightly corroded,
front to rear fuel lines slightly corroded
NSF wheel bearing has slight play.
So all in all a pretty good result.
Now I have to put in back in the garage until after my operation, but at least it will be ready for me when i'm up and about again.
Right indicator repeater working but had to fudge a repeater for the left one as the LED would not spark up and had problem trying to access cables behind dash.
