1. I think I have a slight misfire. If I am going about 30ish in 5th and give a bit of throttle it doesn’t seem as smooth as a V6 should be. Was given a gasket which I presume to be a inlet as it has three holes, when I picked up the truck.
Guy at the garage said it was there when it was PXed.....
Cant decide whether its missing or just bumps in the road...
2. No aircon. Knew this when I bought it, but was such a bargain I had to get it, even without the AC working. Nothing when I push the switch, not a relay click, LED or engine rev change. The gas was changed about 6 months ago to see if that would cure it. Could it be as simple as the relay?
3. Rear lap belts. Is it possible to get these changed for three point ones?
4. Load cover. can I get one and is it easy to fit?
5. Has anyone fitted an electric aerial? The mounting is inside the wing and that put me off straight away..
6. How simple is it to remove the fabric from above the rear load space to fit an aerial for a two-way radio system on the roof?
Cheers guys in advance, any info is much appreciated
