hi all,
ive recently done a cylinder head rebuild on my truck, i had some issues with it not starting, so called in a chap who figured out it was the ignition timing (i didn't even click that i had to set it again), anyway, he got it going really sweet, then the cam shaft oil seal went, so i replaced it along with the timing belt.
do i have to reset the ignition timing, as it seems to be running a bit sluggish, which it wasn't doing before the oil seal went.
