ok guys i need some help this time. the fault is:-press the cruise control button,green light on dash lights up to let you know its activated,but then when you go to use the accelerate up button nothing happens.sancho has this ever happened before mate???? ive checked all fuses,that i can find,drivers kick panel and under bonnet and ive also checked the rad cap vince and its not that.
cruise control,fault
You need to set it first.
-Turn the cruise on (left hand button), green light comes on.
-Accelerate up to the speed you want (up to 110kph, it won't set any higher).
-Press the bottom of the right hand button for a second or two and it should hold at that speed.
-Press the top of the right hand button to accelerate (will go above 110, but will drop back to down to 110)
-Press the bottom of the right hand button to set the speed lower.
-If you brake, press the top of the right hand button to resume at the speed you were at before (unless you've slowed down loads)
Cruise Control
Hi had a problem with mine on my 4.2 Landcruiser, then l notice the Brake warning light on turns out my Brake Fluid was low because Pads had worn. Put new pads in and everything fine now maybe yours need checking.Live Life To The Full
