water problem
  • #16
    £1500 - Zavoli squential injection system & 2 x 50 ltr tanks
    I have a friend who owns an LPG conversion business. I put the tanks in and piped everything through and assisted him with the wiring etc -
    it works really well and £ for £ I get about 40 mpg
    NO WORRIES!
    Rusty
    • #17
      OK
      I have now put the recored rad back in but still i get cold air coming through the heater even when up to temp. This is driving me MAD. Top rad hose is hot bottom one isn't. What do we think ? Stuck stat OR curplunked motor.
      If i don't get this sorted the men in the white coats will be coming to get me and to make matters worse we had 4" of snow here and i couldn't go out to play
      BOO HOO
      • #18
        Originally posted by MAD MANXMAN
        OK
        BOO HOO
        see post #7
        [size=5][/size]
        • #19
          Originally posted by gemini
          airlock in system
          IS THIS COMMON
          ANY CLUES HOW TO GET RID
          I USED TO GET OR SHOULD I SAY HERE WATER SWISHING AROUND THE SYSTEM BEFORE BUT NOW NOTHING.
          WI FIT STAT THIS WEEKEND AND FLUSH THE SYSTEM, THIS SHPOULD SORT IT
          • #20
            IS THIS COMMON
            Have you looked in the tecnical section. There's an article there on airlocks in the cooling system.
            • #21
              RAD DONE
              BUT I HAVE A CRACK IN THE BLOCK NOW
              NEW ENGINE PLEASE
              • #22
                v6 petrol
                • #23
                  iff its petrol the toyota supra block will fit with slight mod as far as i know. other info was deleted
                  • #24
                    The Supra 5M engine will fit as far as I know - think Elvz is doing one on one of hers. Needs some mods and I think the Sump has to be changed because the bulge is in the wrong place (front rather than rear).
                    You might be able to have the block stitched on the V6 without it causing any real problems. Might be cheaper than going for a new engine. Alternatively the cheapest way may be to get one imported from the states. The shipping will be quite high but you should be able to get one fairly easy. Post a question on www.yotatech.com and someone may know where there is one. If you get it shipped seafreight it will take some time but would be cheaper.
                    • #25
                      YES PLEASE !!!
                      been to IOM before on an R1
                      beautiful place
                      i would really be up for this
                      as long as we dont have to cross in that rusty bathtub the king orry again.
                      regards
                      Paul.
                      • #26
                        THE SUPRA ENGINE IS A STRAIGHT 6
                        not v6
                        • #27
                          Try some rad weld.
                          Try to find a used Toyota 92-93 Camry if 4Runners are hard to find, these had a 3VZFE motor which would seem to be the same block. Would be nice to know if they are the same if you find one.
                          • #28
                            not v6
                            Absolutely, however it will fit as a replacement. I was going to make that comment myself but I thought you were making the point of using the Supra engine as a Mod not a straight replacement.
                            • #29
                              it seems there are more options in comparison to a 3.0 diesel
                              • #30
                                now youv'e got me baffeled
                                how many different types are there
                                i have been offered a recon engine for £1800.00 with 90day warrenty
                                do you think this is about right ?
