Hi, Everyone.
Just helped a friend pull down his 92 surf 3VZE, Normal $$$$,blown gasket on right side, front of the head.
Was pretty easy,block was still good,got heads planned down,new head gaskets for both sides,a couple new sensors,while the heads are off easier to install.
Now it looks like we have to do the leads, dizzycap,dizzy etc, has a slight miss on startup,seems like a lead to me,once you get out the garage onto the road she is fine. maybe my friend is being a bit paranoid,i had a drive and to me, it goes like a cut cat!!
We also cleaned the throttle body intake with proper cleaner,made a bit of difference,but still misses at startup and low revs.
which is a pain at intersections,etc.
Anyone else get this problem.
