Right I have just had my car converted to LPG (thanks to Tony and WTV-UK) however when the guy from WTV was setting the ecu etc we found out that my plugs were old and needed changing and upgrading (iridium). So he set the kit up as best he could and tried to get it running but it was really rough but he thought everything would be ok once I put the new plugs in.
So off I went and bought some very expensive Denso iridium plugs and installed them yesterday. Car ran fine on petrol but still rough on LPG so i did a search etc and found out that I should have double checked all the gaps and set them all to 0.8mm. So today I took them all out and tried my best to set the gaps to 0.8mm. Not that easy but I think I managed it ok.
So took the car for a little spin round the block, firstly on petrol till it started to get warm, then I switched over and it was still rough. So I switched back and droive it back to the house on petrol. Parked but left the engine, then tried to flick it back onto gas, (I just wanted to check if it would idle on gas or not) car backfired and made a wee popping sound so I flicked back to petrol quickly however the engine died.
Now if I try toi start it it will only run for a second or so and die, if I accelerate while starting it seems ok but will then die.
Any ideas what I have done?
Please help, I feel very sad at the moment as I have broken my baby!!!!
), then programmed.
