Where is the main earth strap located?
Main earth strap
Main earth strap...?
For what...?
One on each side of the engine bay for the batteries... to the body...
One on the drivers side to the block...
Those are the one I replaced with what can be best described as welding cable... or '0' guage pimpers cable...
There is also one off the starter motor, but to be honest, I haven't bothered with that one yet... Its cut to length and the ends crimped on... just haven't bothered to fit it...
Where does the drivers side one to the block actually connect to the block I have found that mine is not connected just hanging free with a bolt in it looks like the bolt might be from the steering box or should it connect direct to the block.Originally posted by AndyLala View PostMain earth strap...?
For what...?
I would be very grateful if someone would take a look under the cover bit above the drivers wheel and let us know what to connect it to.
I'd say connect it wherever you can on the block for now, and I'll have a look at mine over the weekend, and try to get back to you on monday. ( tinterweb down at home, can only log on from work untill it's fixed)Rob
Still working for the man!
Kenz you have a V6 listed in your profile so you will only have one battery (like me) so the wiring harness will be different than those with diesel engines.Originally posted by kenz View PostWhere is the main earth strap located?
It would help if you had a picture / photo to ID the cable in question?. I do have my truck with me at work today so I can go and check if you like.
Darren, sorry I can’t help as the 3:0 V6 is rather different to the diesel engines.Originally posted by Darren View Postcome on someone please have a look for me,
Mine WAS a 150 bhp V6 and ran on PETROL
