Hi chaps,
i have a tick problem that needs more than the usual medical creams
it is very loud when driving along at 100 km/h
it comes in waves if that makes sense. i am an ex mechanic and have just finished doing the right bank shims as per Toyotas specs. ie
you tell them the clearances cold, then measure your shims once you pull them out. they then consult their book and tell you the shim you need. all seems pretty on to it,,, until you drive down the road after its all complete and Tick Tick ****** Tick.
Question....could an injector be making this noise.? you cant seem to hear it when free reving the car under the bonnet but driving along is loud.
Had the inlet manifold off so many times to look at the cams I can now do it blind folded
