hi i have just brought a imported lhd hilux. i only have one probleam with it. when it is cold it will only pull away in 2nd and will not kick down in any gear untill i have driven it for about 15 -20 mins this is very anoying. can any one help do i need to changr gear oil? or is the box f**ked
usa hilux v6 auto help
 Hi Paul1Originally posted by pau1hi i have just brought a imported lhd hilux. i only have one probleam with it. when it is cold it will only pull away in 2nd and will not kick down in any gear untill i have driven it for about 15 -20 mins this is very anoying. can any one help do i need to changr gear oil? or is the box f**ked
 I have a 3ltTd Auto Surf but I think the same thing applies to all auto Surfs/4Runners. There is an engine temperature sensor tied in with the engine/transmission managment system that will not let the auto box change into top/overdrive until the engine has reached full operating temperature. Mine takes less than 5mins to warm up so if yours is taking 15-20mins then I would check first that the thermostat is working properly and then check the temperature sensor is ok.
 Nil Illigitimi Carborundum
