My 4 runner is misfiring and won't tick over.
It's a 1992 V6 VZN Automatic with EFI.
I've had the AA look at it and discovered that its only running on the 3 righthand cylinders. Compression is ok and the plugs and leads on all 6 cylinders are firing so it looks as though it might be a fuel problem.
Is there anything that I can check for myself ?
