I have a LN130 with a good chassis and body, but a shitty engine, I have a shitty bodied kzn130, but a good engine. Should I swap the engines? They are both manual boxes. I am in a quandary!
kz-te into 2l-te, should I bother.....?
Ah, Mr Surfenstein, Bob here from the HPOC malarchy. I dont mind stripping the vehicles down. It is easy when you have the space, which i do for the next few months. Welding is not a problem, but I might just swap the bodies over and pop in a body lift while I am at it. I believe the heater matrix pipes are different, plus the 2.4 has the rear heater, so I presume there will be more and more pipe work. Is there any other body differences I need to be aware of. Essentially i have the vehicles sitting there, and time is the only real cost. The rest is approaching scrap value too, so there is no real loss.
I cant find a decent write up here, the search is leading me astray. Is there a definitive thread on here?
