A few coolant leaks and minor oil leaks have appeared....nothing too major.traced them earlier today while i was waiting on the dinner.oil filter relocator was weeping a bit,some dowty washers sorted that.rear heater hoses are trickling constantly...i think the factory pipe clips are beyond their best.il replace them with some good quality jubilee clips.
[B][FONT="Impact"]Cut my way in...weld my way out![/FONT][/B]
ended up having to drop the gearbox as i believe the csc was damaged.quite a bit of dismantling to get it out,and the w57 in this,coupled with the transfer box is a heavy old bitch.got all built up by yesterday morning,adjusted the push rod in the MC and got to bleeding the clutch.it was a slow process,trickles of minute bubbles,top up the fluid,leave it for a while,then come back and pump the pedal for another while.eventually the pedal appeared from nowhere and this was the result http://s222.photobucket.com/user/twi...4.mp4.html?o=1
