Just started working on this
steam cleaned and getting ready for paint
got etched,primed and 2 coats of 2 pac silver
extraction
new timing belt,tensioners and water pump fitted.
Decided to remove the egr so made up some plates out of scrap aluminium.
As it sits now the engine is ready to go in.Im waiting on a custom adaptor plate and billet flywheel.Will be using the 1uz bellhousing on the W57 box.The plan is to use a transit CSC and the standard hilux clutch as it was recently fitted with an Exedy clutch kit.The same guy whos making the adaptor kit is also making a takeoff plate for the oil filter relocation.
hoping to retrofit the ls400 calipers to the hilux
fuel pump sorted.mitsubishi galant upper plate/cradle with the ls400 lower portion.i made the cradle height adjustable
extraction
gonna run dual 9" in push formation instead! Steering damper bracket needs dropping on the chassis and the mount needs to be cut off the steering arm and a relocation bracket made. Manifolds have been modified and exhaust is made as far as the axle....just waiting on some silencers.almost there
