3.0td into vitara project - wiring help
  • 3.0td into vitara project - wiring help
    I'm putting a surf 3.0td into a vit running hilux axles on 35's, I have a couple questions with regards to the electrics.
    I have the complete surf to use parts etc
    can I cut the wiring loom of the headlights etc and connect up the pos and neg to the batterie and that be enough for the electric fuel pump and ecu to run?
    also are they immobilised on the keys?
    and what wiring do I need for the auto gearbox?
    thanks
    dont think anyone has done this yet buddy, if you were putting the vitara engine in a surf u may get more help?
    don't think so, depends what year maybe
    all of it
    thanks
    anytime
    ALL THE GEAR!............no idea!
      That will be one quick vitara when finished.
        Would be much easier to use an injection pump from a UK 4 Runner!!
        Regards
        Mark
          Regards
          Mark
          is that a mechanical pump?
            Did Suzota, Tony Bennett have a surf engine in his 5 door vitara.
            Definitely had Surf axles.
            Last time I visited Tony, he was fitting a jag engine & autobox into the vitara.
            That was just before he "retired" & sold his workshop
              Sorry for slow response!!
              Yes the UK version used a one wire mechanical pump IE non "EFI"
              Engine and timing gear is identical!!
              Regards
              Mark
                Any update on engine swap ?
