Lexurf XI
    Originally posted by ROMEROTECH View Post
    It's great that you're running an aftermarket ECU. Oh the remapping joy to be had. That will be fun
    No idea how easy it is to get the factory ECU to run it once you've stripped out all the wires you don't need but i imagine a shedload more hassle to remap than the aftermarket ECU.
    Nice one
    The kit comes with a get-you-on-the-road base MAP. Once up and running you can just plug it into a laptop and MAP it how you like it.
      Originally posted by sadinn View Post
      that does look quite amazing.
      I like it when you say 'the camera doesn't pick it up very well' -so in reality it's an even brighter yellow?!
      I agree a perspex bonnet is the only way to go - why hide it !
      Got to love those shiny headers too....
      It's the flourescent lights that 'tone it down' a bit. Looks better in natural light, especially against the satin black.
        Not sure, but it will be more than stock due to the Tundra headers and
        it'll be controlled by this....
        http://www.spitronics.co.za/shop/ind...products_id=29
        £220 ?
        That seems very competitively priced?
        Anyway, awesome work as per the norm Vince
        Eat.Sleep.Surf.Repeat.
          Originally posted by shokenore View Post
          £220 ?
          Bit more than that, as I had to get the following:
          1 x Spitronics Lexus 1uz ECU kit = R3,464.90
          Map Sensor Type Required 1 Bar (Normal Aspirated)
          1 x Spitronics Standard Transmission Control Unit = R2,201.75
          Gearbox Type Lexus LS400 4 Speed
          Speed Sensor Type Hall Effect 3 Wire
          1 x Spitronics USB to RS232 Converter Cable = 200.00
          1 x Spitronics USB Cable - Venus = 200.00
          1 x EMS Courier = 574.00
          1 x Forex Charges = 130.00
          Sub-Total: R6770.66
          or about £380.
          Annoyingly enough, right now as the Rand is in the sh!$$er - I paid nearly twice that 6 months ago !
          Truck? What truck .......
            Amazing work
              Awesome colour scheme and really like those headers. Where'd you get them?
              I have found these, not sure if they are the same but fairly sure the 3uz headers fit.
              http://www.ebay.co.uk/itm/OBX-Racing...item2c7cc1c7d3
                Lovely, those. But is there room?
                I so need nicer headers. Mine are fugly.
                  http://www.ebay.co.uk/itm/Toyota-Tun...item3cde0d5697
                  • #24
                    Wow! I thought the others were good value.
                    • #25
                      The 4.7 engine (2UZ-FE) is the same block as the 4.0.
                      The only problem is the downpipe flanges are different to the stock LS ones.
                      I'll have a go at cutting some myself out of 1/4" steel with my plasma cutter using the supplied gaskets as a template.
                      • #26
                        Cheap hole cutter if you don't already have one. I have this one and it works well.
                        http://www.swagoffroad.com/Plasma-Ci...ters_c_58.html
                        Brian
                        • #27
                          See, now I feel embarrassed. Because you've (Vince) clearly posted those downpipes before and I've been going on about them lately.
                          Sorry if it seems you've been ignored...there's just sooooo much info to take in
                          Those are great. I guess if you have to make up the exhaust...doing some flanges isn't the worst thing. Well, not when you have a plasma cutter. Bit harder for me
                          • #28
                            Excellent, thanks Brian.
                            I did make one similar to that but it was very accurate.
                            I was thinking of cutting the circle with a hole saw then using the plasma to cut the flange shape.
                            • #29
                              Hehehe!!
                              Might take a while with a Dremel!
                              • #30
