Originally posted by ROMEROTECH
View Post
Lexurf XI
It's the flourescent lights that 'tone it down' a bit. Looks better in natural light, especially against the satin black.Originally posted by sadinn View Post
that does look quite amazing.
I like it when you say 'the camera doesn't pick it up very well' -so in reality it's an even brighter yellow?!
I agree a perspex bonnet is the only way to go - why hide it !
Got to love those shiny headers too....
£220 ?Originally posted by BUSHWHACKER View PostNot sure, but it will be more than stock due to the Tundra headers and
it'll be controlled by this....
http://www.spitronics.co.za/shop/ind...products_id=29
That seems very competitively priced?
Anyway, awesome work as per the norm Vince
Eat.Sleep.Surf.Repeat.
Bit more than that, as I had to get the following:Originally posted by shokenore View Post£220 ?
1 x Spitronics Lexus 1uz ECU kit = R3,464.90
Map Sensor Type Required 1 Bar (Normal Aspirated)
1 x Spitronics Standard Transmission Control Unit = R2,201.75
Gearbox Type Lexus LS400 4 Speed
Speed Sensor Type Hall Effect 3 Wire
1 x Spitronics USB to RS232 Converter Cable = 200.00
1 x Spitronics USB Cable - Venus = 200.00
1 x EMS Courier = 574.00
1 x Forex Charges = 130.00
Sub-Total: R6770.66
or about £380.
Annoyingly enough, right now as the Rand is in the sh!$$er - I paid nearly twice that 6 months ago !------------------------
Truck? What truck .......
Awesome colour scheme and really like those headers. Where'd you get them?
I have found these, not sure if they are the same but fairly sure the 3uz headers fit.
http://www.ebay.co.uk/itm/OBX-Racing...item2c7cc1c7d3
The 4.7 engine (2UZ-FE) is the same block as the 4.0.Originally posted by Kwakka666 View PostWow! I thought the others were good value.
The only problem is the downpipe flanges are different to the stock LS ones.
I'll have a go at cutting some myself out of 1/4" steel with my plasma cutter using the supplied gaskets as a template.
Cheap hole cutter if you don't already have one. I have this one and it works well.Originally posted by BUSHWHACKER View PostThe 4.7 engine (2UZ-FE) is the same block as the 4.0.
http://www.swagoffroad.com/Plasma-Ci...ters_c_58.htmlBrian
See, now I feel embarrassed. Because you've (Vince) clearly posted those downpipes before and I've been going on about them lately.
Sorry if it seems you've been ignored...there's just sooooo much info to take in
Those are great. I guess if you have to make up the exhaust...doing some flanges isn't the worst thing. Well, not when you have a plasma cutter. Bit harder for me
Originally posted by yoshie View PostCheap hole cutter if you don't already have one. I have this one and it works well.
Excellent, thanks Brian.
I did make one similar to that but it was very accurate.
I was thinking of cutting the circle with a hole saw then using the plasma to cut the flange shape.
Originally posted by Sylux View PostSee, now I feel embarrassed. Because you've (Vince) clearly posted those downpipes before and I've been going on about them lately.
Hehehe!!
Might take a while with a Dremel!
