This is the n/s
Say hello to my little friend!
The gearbox mount goes back in the same position on my conversions. (approx 40mm higher though)Originally posted by zem_41 View PostWhere the g/box mount sits viewed from below
You need to raise the engine a little more I'm affraid, that link rod will probably scrape the sump. The rod rises ever so slightly when the steering is turned lock to lock.
Engine tilt is about right though, same as mine.
Does the truck have a bodylift?
Cheers Vince, yeah I thought it was a bit close, Ill have a play with the mounts tmrw. Yeah it does have a 2inch body lift. I don't think I can get it back any more as the cam bung will touch the h/brake assembly. Nearly there now though. Will get back on it tmrw.ALL THE GEAR!............no idea!
