...is very poorly
This thread is aimed mostly at Bushwhacker, questions for getting the old girl back up to full health, but any help is help
1] If you can remember, what was the reg of the donor Lexus? (for parts ordering)
2] I've got left and right main bank oxygen sensor faults, what specific sensors do I need? (seems to be a huge range of the damn things. I can probably look it up with the donor reg)
3] I also have RPM sensor fault, any clue?
4] What is the black bit in the pic below called? I need a new one, it's cracked and she keeps throwing the hose off... Also, what's the grey/metal part behind it that it's attached to? (water pump, maybe?)
5] What sort of coolant do I need to replace the lost fluid with? (filled with water to get me home
6] What does the connector just to the left of the highlighted thingy in the pic connect up?
7] Any idea why the gearbox seems to hang on to a particular gear a bit too long? Loses a lot of power over a certain revs but wont shift unless I let off the gas. Related to the RPM sensor?
I'm hoping that clearing the engine faults will sort out the lumpyness when she's cold, and the high tickover when warm in N or P. The leaky brake cylinder and the rotten/split rubber boot on the front drive shaft I can do!
Any sort of help would be gratefully appreciated, I'm a bit clueless on anything more complex than a 1600 crossflow
