just a quicky to vince or anyone else who may know. with the air con unit being redundant and just on so i dont have to find a new sized belt that fits i have kept the air con unit on the engine. what do think the chances are of fitting some kind of air compressor in place of that unit?
air compressor for air con
Keep the A/C pump but use it to fill a tank for compressed air.
You'll need a tank obviously, e.g. an empty fire extinguisher would be ideal, a pressure gauge, an adjustable auto shut-off valve, plus an in-line oiler to keep the A/C pump lubricated.
Then just apply 12v to the A/C pump to engage the clutch to fill the tank. (When engine is running of course)
just found these on yodatach and a few others so will have a look and get cracking! put the bobbing on hold till weather gets a bit nicer ha!
http://www.pirate4x4.com/forum/toyot...faq-2-0-a.html
http://www.pirate4x4.com/forum/toyot...-c-w-pics.htmlhttp://www.hiluxsurf.co.uk/showthread.php?t=55797
hi Vince could you possibly do me a favour please. do you have the air con elbow fittings or know what size bsp or npt fittings they are? as i dont have anthing to gauge or measure them? no worries if not i will try on lextreme at least for the fittig sizehttp://www.hiluxsurf.co.uk/showthread.php?t=55797
