Hi All,
This is my first post here, but i've been reading for a good while. It's a really great forum, and you guys have a wealth of knowledge, which I'm hoping you could share with me? Anyway, to the point i'm planning to build my own lexurf. I've never done anything quite this big before (a couple of like for like engine swaps and a bit of fabrication). I know it will never be up to bushwacker standard but i'm more doing it for the learning experience than anything else. Hopefully you guys will help me when I get stuck?
Anyway, could you lucky sods that already have lexsurfs let me know what kind of MPG you get from them roughly? Also, how does the 1UZFE take to LPG if anyones tried it?
I have to say this, Thanks for your sympathy on the back it's is appreciated. As for the rest of your post
! How much hacking and soldering of wiring looms etc is actually required, for the most simple solution? What's the easiest solution with regard to clocks etc you've found? You used the Lexus cluster did you not?
