Originally posted by an1mal_69
View Post
Then plug all the open ports on the plenum/throttle body.
Make up a blanking plate on the side of the plenum but leave the valve cover breather hose port open to connect a hose onto it to the PCV valve.
The Celsior plenums are undrilled/tapped at the back for the EGR pipe.
I really should be charging for all this information that took me months to research you know!
