To fit a Lexus V8 in a Surf without doing a body lift? If not, Is that steering link the only limiting factor?
Is it possible
Originally posted by gary-r View Postyes - vince has one in the shed now, its the red one from you know where.
And it started first flick of the key after I plugged the new ECU in.
Andy it is possible, but you'll need to modify the sump and suction tube inside to clear the relay rod and dick about with the radiator and fan as the space is tight because to engine will sit further forward without the body lift.
Would any of the other sump pans and pick up pipes work?Originally posted by BUSHWHACKER View PostAndy it is possible, but you'll need to modify the sump and suction tube inside to clear the relay rod and dick about with the radiator and fan as the space is tight because to engine will sit further forward without the body lift.Do you know that, with a 50 character limit, it's
I'm in no rush at all, I'm still running around in my Lexus. I'm not 100% sure if I'll need them or not. I'll have a look around, on line, to see if there are any patterns or the likes.Originally posted by an1mal_69 View PostYea, should have the job lot - sump pan, ally brace & oil pick up. Hopefully getting my soarer bits this wk. Away on hols Sun however, don't think im going to have chance to swap them over before i go
How much do you want for them?Do you know that, with a 50 character limit, it's
