Would you put a V8 in a 2nd Generation Surf or a 2 door Hilux pickup with leaf suspension?
Given the choice
Both?
A Surf is a perfect all round SUV, the V8 complements its perfectly. A Leaf sprung pickup is really only good for fun or work, in which case its a little overkill.
(says the man who had a 81' V8 tray-backed pickup as a daily driver..)
Tony, I can't do both, Shirley would murder me! And I'd not tray back either, I don't like them.
Vince, I've read about the Tundra headers (2 bolt flanges?), but not the sump. Any sump comments I've seen related to Soarer engines rather than the LS one.
I've mentioned the pickup before and I've just been offered a 2nd gen for "a couple of hundred". I'm not sure what a couple is at this point, bearing in mind that, in Scotland, a monetary couple isn't necessarily 2! I can see pros and cons with both, just canvassing opinion.Do you know that, with a 50 character limit, it's
That's one of my cons, rear articulation being another. Triangulated 4 link rear suspension and coilovers would fix that though.Originally posted by BUSHWHACKER View PostToo much power in a pick-up is a waste IMHO, there's not enough weight over the rear axle.
I could always take the pickup and use the front axle on the Surf?Do you know that, with a 50 character limit, it's
yea, butOriginally posted by Albannach View PostThat's one of my cons, rear articulation being another. Triangulated 4 link rear suspension and coilovers would fix that though.
you dont offroad...............私のホバークラフト は鰻が一杯です。
Do the surf then later if you want SAS it.
I plan to chop cage and off road this 2nd gen. The ifs can work well but I may SAS it in the furture and send it to Wales for a little engine mod.
I voted pickup just because I want to mess with it
A properly set up leaf sprung front end has looooads more travel that a IFS, the diff goes up a long way (I broke my oil filter off my Rover V8 once with it) The torque arm bracket sticks up a long way to.Originally posted by BUSHWHACKER View PostIt's something to do with the solid axle and spring mounting points I think.
Too much power in a pick-up is a waste IMHO, there's not enough weight over the rear axle.4x4toys.co.uk - Keeping you on and off the road...
Exactly my plan over the next 18 months. Already snapped 1 front shaft with just 31's an the 3.0lD..yea the front diff is locked, but that just highlights the weak points in the IFS. If I were to go with bigger tyres as well, I think I'd be breaking shafts and cv's pretty frequently, nevermind factoring in the grunt from the V8.Originally posted by yoshie View PostDo the surf then later if you want SAS it.
V8, SAS.. 3-link front on Fox air 2's or coilovers, 4-link rear on the foxies too
Time will tell, but that's the grand plan anyways
