Lexurf IV.
  • Blimey...I'm actually excited.
    and off to bed...I have a bet with the boss. The hummer going for mot tommorow is going to be impounded at the test station.
    Non intercooled nothing.
    • GV9'nd at the test station Gra
      Jess
      "Cos short cuts can cost more in the long run"
      Buncefield Burner
      • Originally posted by Diezel Weazel View Post
        Jess
        I just know it's gonna happen jess. Wish me luck!
        • Well ya just can't have all the Luck Gra !! can ya ?
          I mean a Lexsurf n a MOT on a 8ummer ....
          Fingers crossed Gra
          Good Luck with it
          Jess
          Buncefield Burner
          • Well...I've been impounded. I spent last week on steering and brakes. With regards to the steering, I replaced all ball joints, and tre's. Bothsets of wishbone bushes and the aftermarket ball joints on the steering arm. I renovated all four calipers and the master cylinder. This system has no servo assistance, instead it uses a hose from the power steering pump. This applies a constant pressure to a diaghphram acting on the back of the spring loaded master cylinder....it's all wombled. The owner wouldn't spend out on a new master cylinder or diaghpram. The net result is poor braking. I alfo got in to find the (20 feet long) handbrake cable had snapped. The exhaust has numerous leaks, the torsion barsubframe is twisted, the prop carrier bearings are shot, as are all 5 rear uj's....amongst other things...anyone got a taxi number.
            • Sounds more like a rebuild Gra .. ..
              No chance of a cab either, I gave up driving 7i7s around in a Taxi over 25 years ago ...
              Jess
              Buncefield Burner
              • Just got a call...it's been recovered to the yard. VOSA have installed a mini tracker to ensure itdiesnt leave the yard!
                • Are you fetching a rear bumper with you?
                  If not, then I'll make the rear end look more presentable for the drive home.
                  • Originally posted by BUSHWHACKER View Post
                    I've got a rear bumper on order vince. The breaker near me has two ,2.4's coming in next week.as soonas I get it, I'll courier it upto you...and damm plugs and belt. The belt is now coming here tommorow, shall I send it, or is it an easy change myself? The leads are due tommorow as well.
                    • The leads and belt we can change when you're here, only a 10 min job.
                      I'll leave the covers off ready. Looks a bit like a Hemi V8 without the plastics on.
                        Hope it goes better than a hemi...
                        • Only 4 more sleeps (well onesleep will be a night shift)...best get the industrial strength absorbent pads ready. Wouldn't want to mess up als motor now.
                          • Originally posted by gwh200 View Post
                            Best buy in bulk then .
                            Neal
                            • envy
                              lucky barsteward - wish it was mine, post a few pics of the beastie so i can drool - you must be happy smiley person this week hehehehehe.
                              • Got a bit of a grin on, that's for sure.
