No problem mate, not that I did much mind , did you sort the gearbox in the end?
Yup...took it backout today. Welded some spacers on to the torque converter to push it onto the gearbox shaft a wee bit more...flex plate straightened up...jobs a goodun.
Glad it's sorted, they do appear to be a bit of a sod to work on, I too managed to carry out some repairs....................... .........
Coils ross, and whilst i was at it, new plugs, cleaned the AFM with brake cleaner and snipped the cold start injector wire on the ecu...the difference was astounding. I still have a tiny misfire, but a new AFM from ebay and an 02 sensor should sort that.
excellent work mate wish i had the time and wallet to do that will be doing the vents mod though just one question any probs from water with the vents may sound like a stupid question but remember something my uncle said after fitting a scoop to a car that it just killed the engine with all the water he had to add drains
but really want to let some of the heat out i still also have the covering on the underside of the bonnet so will more than likely have to remove this will i notice much increase in noise
