Howdy All
I have done all the research on this site and have all the relvant information about taking it off the mounting, putting it in a vice and priming of the pump etc.
I am such a loser I can't even get this far - the filter mount has two hoses attatched and one electrical connection at the bottom, do i remove these? Is diesel going to go pumping all over the street if i do?
The electrical connection is there a knack for this i can't see a way and don't want to force it cos i might break it.
once these are off, the filter can come out, assuming that undo is anti clockwise this is holding the filter up the way it is in the vehicle, right?
Cheers I feel thoroughly miserable now i was trying to sort that bit b4 it got dark - ah well at least i did the easy bits putting in the air filter and changing the rad cap!!
But before you refit the new filter, fill it with clean diesel and this cut down/out pumping diesel through the new filter.
