finally got round to rear diff oil change
I ordered the LSD oil from Difflock - even though at 143k mile i knew that the LSD clutch will be kaputt in the rear diff, and i have tested it and it doesnt work.
drained the oil, worrying thing is 3 chunks metal - small 'teeth' came out and some swarf on the magnetic plug. So guess the rear diff has lost some teeth, and worn.
oil was in a right filthy state,
cant afford a new rear diff, so will just have to see how it goes,
someone in the vehicles past must have had it in 4wd on tarmac to shear gear teeth off,
