Hi,
O.K, my motor is a '95 3.0 diesel auto. It runs 100%, very reliable and has done about 55000 miles. However sometimes when i switch the engine off there is a very untoward sound coming from under the bonnet. It is generaly a sharp knock followed by a short whine!? It is very unusual so if anyone has any advice, i'd appreciate it.
Also the rear window mechanism is starting to struggle to extend/retract the window. Will more than likely strip the tail down and give it a good greasing so again any tips/ common snags will be greatly appreciated.
Thanks guys, Wilko.
Thanks guys, Wilko.
