First timer
  • First timer
    Hi!
    I've been trying to collect information / advise on carrying out an engine / transmission swap on my 1982 Hilux Single Cab Pick-up and came upon this website.
    I bought the pick-up recently with an L engine and busted gearbox and transfer case. After scouting around I've located a 3B diesel with complete transmission from a 70 series Land Cruiser.
    Any idea if the 3B will fit? I've been told that the engine might be too high and the gearbox too big...
    All help appreciated.
    Simon
    Originally posted by 28SRI
    Hi!
    Simon
    Simon.
    I think that advice is pretty sound. The 3B engine is very tall, not sure about the gearbox.
    Also the 3B engine is somewhat agricultural albeit a completely sound engine with no know faults. It has very little power but a good torque spread.
    I would suggest that if you already have the engine, sell it, they are pretty rare and someone with a BJ40/BJ41 etc would snap your hand off for it. Then get something a bit newer for the Lux. If you want diesel, get yourself a second hand 2L engine or a 2LT if you can get one. If you want power go the Rover Bacofoil V8 route.
      Thanks Andy, appreciate your quick response and advice. I hadn't bought the 3B so no unnecessary expense there.
      I spent last evening calling the 4x4 club members about 2L and 2LT engines and managed to locate a 3L engine and gearbox in a wreckers yard a few hours out of town and will go and have a look on the weekend.
      Best regards,
      Simon
        Best regards,
        Simon
        3L engine is a good one, you can even fit the turbo and ancillaries of the 2LT engine to it if you can get one. You then would get a 2.8TD engine which would give you a lot more power and torque than the 3B engine anyway.
        Plus the 3L engine is standard fitment in some markets on the pickup so fitting it is relatively easy - you may need to move some engine mounting points though.
